Did my timing belt/waterpump job (tkt021 kit) last month and figured I'd replace the fan bracket with a new OEM Toyota one while I was in there. Within 400 miles, the engine sounded like a jet motor at higher RPMs (sounded "airy"). Checked for vacuum leaks, cleaned the throttle body and MAF, checked the PCV valve, checked the snorkel for blockages as well as exhaust system. Checked the timing as well. As it turned out, I decided to try and "spin" the fan while the engine was off. Aaaaaaaannnnnnd....fan is locked. Can't believe the fan clutch decided to crap out right after I put in a new fan bracket. Oh well
