Flank
American by Birth, Texan by the grace of God.
As a precursor, this is NOT a "my engine runs too hot" thread. Actually the opposite.
Prior to my radiator swap last year from 20year old OEM to new Koyo OEM clone, my average engine temp on my "permanently" installed Scangauge was 186* to 190*. After the radiator swap and new OEM thermostat, I have been regularly getting engine temps lingering in the high 170s for a while, until settling around 181* during warmed up normal driving. To me this has always seemed too low. A recent conversation with Mike from Frisbee offroad about a possible engine rebuild or swap brought up fuel mileage and engine temps led to the question as to whether running this cooler temp could make the engine run rich to attempt to warm it up more, and lead to reduced fuel mileage.
Suspecting that the t-stat was the culprit, I swapped out my thermostat this weekend while replacing my heater valve and noticed that the thermostats (new OEM and old OEM) have 82* (C) stamped on them, which equates to 179.5* F or basically 180*. This coincides with my current engine temps, but is contrary to my previous temps and expectations due to on Mud.
The only other variable is the koyo radiator. Seldom have I heard the complaint that the rad is running "too cool" and the t stat should take care of that anyway. I'm wondering if I need to switch to a higher temp t-stat.
