Depends on the region they were made for but it is by the base of the brake pedal on the ones in the UK. Having the port doesn't mean an ODBII reader will work though, again it depends where it was made for with the USA seeming to get ODBII much earlier than the UK / Europe.
Put your vehicle year and model info in your sig line so we don't have to ask for it each time you ask a question.
My 2003 build vehicle has the port but is not enabled for OBD-II, I expect MOBD though. Not sure but it's possible 2005 on vehicles may be OBD-II compliant.
The OZ vehicle ports are the same spot as the UK.
ODBII is a USA thing...
Hdj are not sells in US, why Toyota would have wasted time to have them ODBII compliants ?
Well, from "I don't remember what year" ALL cars (using gas) sold in US must be able to be easily and electronicaly tested using the same method.It's not just a USA thing.
That's why the connector is always around the driver area with a "no tool needed" access and that's why available data are admission,ignition and exaust related.
The goal was to check the engine efficiency and determine the pollution level
So, as Toyota already has his own ( more complex and powerfull) communication protocol and as Toyota doesn't share technical things, why would they waste time doing something nobody ask for ?
Some other country may use ODB, but it was first a US requirement...That's what I meant
Yes, I'm sure...VW, Volvo, BMW, Benz, Saab, Opel... cars also sold in USABut I've found many european cars also use the OBD2 plug and protocols (scangauges work on them).
I'm agree with you, would be same spec.I suspect it is exactly the same spec as UK models so there's a small chance it may be OBD2 compliant.
Sadly, test have been done on earlier LHD Euro HDJ100 and they were not ODB compliant
I don't remember the production year... hope you're gonna have more luck than my friend.
I heard post '02 diesel engine sold in Europe would be ODBII compliant... so...
I'm gonna ask some friends for you...
I'm not sure, but I think this engine came in '02That's a shame, but thanks. This vehicle is 01 I think, europe got a commonrail version of the 1HD-FTE at some stage with a variable vane turbo. This vehicle has the VE pump and CT26 turbo.
OBD2 has become a standard for diagnostics, while it started in the US it's worldwide now.
There is no commonrail version of the 1HD. I've seen the "rail" reference of Adonis - don't know what they refer to, but it might be the "rail" of valves on the intake manifold on the latest versions, regulating the intake flow speed by closing one of the two ports/valves for each cylinder. I suggest that someone French-speaking contact them to find out the difference between the four versions they list. Hint hint. (Wish I could, tried a course: French for beginners once - the instructor was cute...)I'm not sure, but I think this engine came in '02
With an Adonis chip, you can have 295hp (no warranty issue, sold by dealer)!!!
That's our man, hereby officially so.1HD-FT was the 95 trough 98 LC80's diesel engine, it became "E" for the 100, with electronic injection from 99
Vane turbo ( geometrie variable) appears in 01 or 02, and also liquid cooled egr.
I'll send a request to Adonis... my french is better than my english![]()
You're welcomeThat's our man, hereby officially so.
Merci beaucoup so far.
