ARCHIVE NOS OEM Toyota High Pressure Power Steering Hose w/ Return Line Also Combo Set Up Great For JDM & NON-USA Conversions & Retrofit 44410-06142
  • Thread starter Thread starter ToyotaMatt
  • Start date Start date
ToyotaMatt
NOS OEM Toyota High Pressure Power Steering Hose / Line
w/ Steel Tube Return Line Also Combo Set Up ,.
Super Heavy Duty / TOP SHELF Assemply
44410-06142
$39
USPS Flat Rate Box Ride
What Power Steering Box would those hose work for?
are you calling the shop hot line right now ?
le tme know im waiting
thanks
Hi Matt,
I need lines for an 1HZ to 60 conversion - any idea if this fits that need? Interested if so - thanks, Pete
well
not sure ?
i DO have My reproduction Fj60 High Pressure lines set up too going on , i can say that will work mounted to a fj60 steering box and to a toyota pump ......with a good degree of certainty i would think ?
see link here please
i also , just got in my FJ62 Reproduction high pressure lines set up
i will have photos shortly here for u
its HUGE !
This is cool. Hard to sort out all the banjo fittings to cooler lines to gearboxes to pumps; I am trying to do it from a late 1HZ to a factory 40 series gearbox.
well , its priced to move and help out the right person too
u can get it re-worked a tad if need be too ?
if ANY ONE has a live sample of a period correct application they need done up im game ro reprodyuce it faithfully by its oem toyota part #
i cant do any kustom one off work , to be clear here , sorry ...
i want a HJ61 high pressure line in good un bent or NOT all jacked up condition
leaking is fine
but the shape and bends must me unmolested to work
fyi
the HJ61 set up is common enough and i have been asked enough times to approach this i short order !
get her done !
leaking is fine
fyi
get her done !
I'm seeing that 80 series line will work for 1hz to 60, so thank you but I'll look in that direction. Pete
this is considered a conversion correct ?
or some overseas 60, 61., or 62 came with a 1HZ factory
or a MOD
i did know this if they did ?
or a MOD
Yeah, just a plain old US 60, and a Euro 1HZ. Some parts are apparently direct fit - alternator and PS hoses from 93-97 80 series are a couple so that helps! Cheers, Pete
you need a factory japan DENSO New alternator by chance for a 80 ?
please review this link below :
first time mud member clients get 10% off there first welcome to out wonderland parts store invoice , all of the total
no rules no games , only just right
