ARCHIVE NOS JAPAN Genuine NipponDenso 50a AMPS Alternators Units ALL same UNICORNS FJ40 , FJ55 NON-USA FJ60 , External Reg F , F1.5 , 2F Non USA
  • Thread starter Thread starter ToyotaMatt
  • Start date Start date
ToyotaMatt
50a AMPS
Qty x 8 Alternators Units
ONLY 3 Remaining ....
ALL same this will never happen again like these UNICORNS !
FJ40 , FJ55 , FJ60 ,
w/ External Reg
WILL FIT 1963-12/74
FJ40 USA
and Passenger side Upper
Locations USA and NON USA 2F
MUST have the 2 pin FEN metal PLUG connector like photos below
WILL work with either a 6 wire or 3 wire External Regulator ONLY
If you NEED help ID'ing your current set up and my NOS units WILL work ?
Post Pics here in this PM please
IF YOU can't or Will not post pics , then Use this LINK to sign up for unlimited Photos hosting here on MUD
sorry i no longer Accept text messages to my shop hot line due to the RECENT issues my assisted had caused using this approach ......
GET ON BOARD and SUPPORT MUD who Supports YOU
thanks
units run $245 each
YES if you purchase more the one the price drops ....
please PM to discuss this ....serious PM only Please
Any chance you can post a clear picture of the NP label?
@ToyotaMatt These are an exact replacement of the factory for a 1984 FJ60? Thanks
under Norman USA Spec. Circumstances , NO
These use a Remote or External Mounted Voltage Regulator set fire wall or Fender Mounted
FJ60 1984 uses a PIGGY BACK Style Mounted Regulator , the small BOX saddled to the outside of it
does this make sense ?
i do not want to post a bunch of FJ60 Units Photos here in my listing , this may confuse folks
However , Many NON-USA FJ40 with a 2F engine , this Unit WILL work ,
please ALWAYS Refer to this photo for correct possible UNIT NEEDED identification
the 3 wire FEN metal Plug socket is the smoking gun for correct application in most cases
If Anyone has any Questions regarding correct application fitment etc.
please post a clear up close photo of the 3 wire socket plug connector , i can help make the correct determination of correct application or in many cases this unit i have above is indeed a UPDATE or UPGRADE to a old tired 35A -45A Units , it being a 50A unit itself .....
- If you have a Green Plastic 2 Wrire Plug or a Green Plastic 3 Wire Plug , this IS NOT the correct unit for you ...fyi
PM me , i DO Have 3 wire green plugs availble also in-stock ....
good evening Ernie
These are Genuine NipponDenso Units From JAPAN , much like a Store brand KYOSAN Fuel Pump without the Toyota name stamped on it or in the case of a AISIN Blue Box water Pump the Teq Logo has been ground off for unknown reasons there on that
so based on these facts , i have taken the time to measure the Lower PIVOT point flanges or tabs center to center Inside dimensions , also the top tab is a straight tab NO angle to it .........
These are indeed 100% a TOYOTA Land Cruiser Parts Application in every way , and WILL bolt on and Plug and Play providing you have the correct application info i have carefully outlined above .....
These are NEW units , NOT Re-manufactured
i have several NipponDenso Alternator Application Guide Books in my Library and these match every spec. i have listed thus far
- These are NOT a TOYOTA Genuine Parts Tagged Unit to be clear , ONLY Store Brand NipponDenso unit , is there a difference here on this particular point or spec. ?
- NOT in mY opinion , when a NEW unit made by NipponDenso japan went from There factory at the Robert Bosch / DENSO assembly Line in Japan , then to Toyota factory Plant A-11 for final install on the assembly line , Nothing additional was done to the unit except a TOYOTA MOTOR Corp. Propitiatory ID tag was affixed to it ......
Please feel free to PM me with any further questions , or post pics here of your old unit in question you wish to replace it with , i WILL make a concrete ID for you either way ..........
i hope this helps answer your question my friend ......
thanks matt
I see it on the top side of mine with the Denso logo in red. It makes sense.....thanks for clarifying.
If you Need a 1984 FJ60 2F Unit , Please PM me i have some good Options for you ,,,,,,,,,,
matt
Matt,
This is what's on my Jan 1977 FJ40.
3" or 75mm mount spacing
Ill post what's on the May 1968 FJ40 on Sat AM.
Thanks
Ernie
Matt,
Thanks
Ernie
I like to give Something back to my clients :)
So traditionally ALL alternators I offer come with complimentary
New OEM Yazaki 3 pin UV rated connectors for the FEN socket and 4 terminals solid brass and a B+ ring terminal boot JAPaN 🇯🇵
Yazaki parts all OEM ..,100%
My way of saying Thanks ...
