Howdy everyone!
It's been a while since posting, but I have a question for you all. I have an 86 FJ60 with a Chevy TBI, NV4500 transmission, 34mm split t-case, stock front axle, and a FZJ80 rear. Front has a ARB air locker and the rear has an Aussie locker.
The question is, when I am driving down the road in 3rd and 4th, it sounds like marbles are rattling around some where in the drive train. I have not yet put a stethoscope anywhere on the drivetrain while on stands yet - but my hunch is either the t-case or the rear end gears. The noise gets worse in 4th, and even worse in 5th but 3rd still has it. Also, the noise only comes when I am going from load to no load, once I am coasting with my foot off the throttle, it subsides. The noise does, however, persist when the trans is in neutral and coasting at any speed.
Things that I am going to check are:
1) put trans in neutral, t-case in 4wd and see how much play is in the t-case gear box.
2) put on jack stands and run in 3rd, 4th, 5th and use a stethoscope to find where noise is coming from
3) ?
Thanks for any input!
Cheers.
3) ?
Cheers.
