mmmmm Sounds yummy!
They have a sausage shop too
Cooked a 5-rib USDA prime grade standing rib roast last weekend. Used the slow roast method (8-hours @ 200 degrees to 118 degrees...let it come up to 128 degrees then back into a 500 degree oven for crust treatment...ala Alton Brown). Awesome flavor...but for what the damn thing cost it was not as tender as I would have liked/assumed it would have been. But it was nice, since this group liked rare to medium rare, the slow cook approach turned out the most evenly cooked roast I have made to date.
unless it's been dry-aged for a week or two, I haven't noticed much of a difference (for roasts) between choice and prime grades...then again...I haven't had too much experience comparing the two side-by-side...
so where do you rank Top Sirloin on your list of cuts??
lunyou
lately, I've been into "flatirons". good beefy flavor like a strip, tender like a london broil, and cheap like flank steaks.
Noah I checked your CAB dealer URL and ONE store somewhat local to me showed up - a small grocery store in an adjacent town called Joseph's SuperValu.
I just now browsed through there on my way back from lunch and they had a decent selection of CAB-stickered steaks, and it looked okay, but none of the CAB-labeled meat was marked with a USDA grade. I assume it's not all Prime, is it at least all Choice? Or should it in fact be labeled, meaning I should stay away?
I have no place to buy good meat here, even the one butcher shop has nasty stuff. The general population here are uneducated cheapskates, so premium versions of anything have a hard time making it here. WalMart is the biggest meat seller here I think...I checked out the meat counter once there and found that almost all the beef in the store has MSG added to it.![]()
lunyou
not sure how Noah will respond, but IMO, top sirloin is a fairly decent lower cost cut.
but whatever the cut, I think the most important thing to know is how to best prepare whatever cut you have on hand.
CAB is USDA certified and is given a G1 stamp......all CAB is USDA top 1/3 choice or Prime....
I figured CAB was "certified angus beef". In which case it's a steer type, not a USDA grading.. Am I missing something?
10-4CAB is USDA certified and is given a G1 stamp......all CAB is USDA top 1/3 choice
CAB is the highest grade choice. There are three tiers of choice and CAB is at the top. If it were CAB prime it would have said prime for sure.
Noah check your privates!![]()
