I haven't started my 1999 LC100 for a good while, probably since early last year? It's been sitting neglected due to the booster brake failing, and I replaced that, but now it needs a new caliper on the right rear because the bleed screw is rusted in place. So I went to very carefully drive it onto a trailer to get the caliper replaced at a shop and the brake lines flushed all around, and it won't turn over, although the dash seems to light up. I realized that the fob on the key wasn't lighting up, and replaced the battery in case there is a security mechanism that won't start the car with a dead key. That fob now lights up, and will lock/unlock the doors, but the car still seems unresponsive.
I do hear the brake booster failure tone, which was expected. It has been on a CTEK MUS-4.3 charger for a long time, with the battery ground terminal removed. The CTEK charger was completely off for some reason, which I didn't realize until I opened the hood to connect the ground cable to the battery, and that might have allowed the battery to get low, even though the 100 obviously didn't drain it. So I unplugged the charger and reset it, and it's been charging since Thursday. Or so I thought. Just checked it again, and it was OFF AGAIN? Not sure why. I replaced it with a CTEK 5.0, just in case, and will give it a while. The indicator was on the third dot when I closed the hood.
Anywho, in case it isn't the battery being low, what could cause it to not turn over at all? It's doing nothing. Doesn't sound like the starter is even trying to go. At this point, I can't even take it to a shop, because it won't start, and I don't know any LC-smart folks who can/will come to my house, so I was hoping for some insight here. TIA, y'all!
