- Thread starter
- #21
I found this pdf that kind of explains how the canister works. http://www.endwrench.com/current/spring04pdfs/EvapEmission.pdf
here is the 94 info
Thanks for the docs. I will test these components this weekend.
here is the 94 info
It should rev higher than 2,500 RPM. That climb was not huge. ...
If the feeling was pretty much like your high range hill climb attempt, I bet you weren't in first gear...
Last year I drove the Durango, CO to Ouray (550) with my 92 and a M-416 trailer loaded (probably about 850 lbs total). Power was so bad I had to use low, 2nd gear on most of the climbs up hill (pavement). This year I changed my fuel sock and pump because of lack of power and stuttering after driving about an hour this summer. That problem is fixed. Doing the same trip next month, I hope mine is better. Fuel sock was definitely sucked in, probably original (300K miles) and bad.
I'll definitely post my results on this thread at the end of July.
You can look forward to 2nd gear high range this year![]()
Adjusted the system pressure
