You are probably looking at two different problems. First, I would be suspect of O'Reily's scanner. Most of those monkeys at the chain part stores are at the top of their career ladder and only know what their computer tells them. You need to have it scanned by a known scanner that works on your Toyota.
How bad is it missing? Is it something that new plugs, wires, distributor cap, and rotor will fix? Or is it a case of no power with an obvious cylinder not firing at all? If it is the first situation, the computer will most likely not throw a code anyway.
I am helping out with this fix. When we were at the store,
this is the scan tool that was used. It is supposed to work for Toyota / Lexus 91-95. I don't think all stores do this, but the manager is a close friend so he always helps me out the best he can. Money's a little tight right now so we need a good scientific, specific diagnosis and can't play parts roulette.
If we're going to talk about the misfire in this topic:
SYMPTOMS:
*The exhaust "Smells" rich
*After the engine is warm, it stumbles/has no power at idle and when accelerating to about 2500 RPM. Above 2500 RPM, it smooths out.
*No Check engine Light
*Runs like a raped ape when the engine is still cold
*Not seeing any smoke out of the tailpipe other than some residual oil from time to time from valve stem seals leaking.
*PRND32L lights do not work, reverse tail lights do not work either
*Last night the stereo amplifier started making static so I unplugged the power going to it to stop the static and the truck seemed to run a *little* better, as strange as it sounds. This leads me to believe I need to check the wiring to the ECM behind the glove box, which I'll get to in the next few days.
WHAT WE'VE DONE SO FAR:
*The dizzy cap/rotor is clean and not leaking any spark,
*The coil is good,
*the plugs are fairly new,
*Plug wires test good with a multimeter. No arcing is present either.
*The engine harness by the EGR stovepipe is fine and I have added extra heat sheilding to it as a preventative maintenance item.
*Tonight I will be checking the ecu harness in the cabin.
