Wanted NM Miscellaneous Small Distributor Parts
4Cruisers
Looking for a handful each of these small F engine distributor parts. The small cam pin used for adjusting the point gap is removed when a Pertronix kit is installed, so there should be some of these floating around - they're NLA from Toyota. Same with the terminal fitting and hardware - I believe these are still available new, but I could use a few good used ones if they're out there. The other part is the U-shaped advancer part that engages the post on the breaker plate - these were never available separately.
As an alternative I'd be interested in buying a few inexpensive older distributors and/or advancers that are only good for parts, especially if they have some of these parts.
I have a few extra insulators I can spare for sure. And maybe an old advancer diaphragm with the block still on it. I saw the box of parts on the floor yesterday and was trying to decide where to move it, now that more shelf space is finally becoming available. So I can probably put my hands on those easier than the vacuum hose clips. ;)
And then there are these:
15 adjustable vacuum advance dizzies in storage... because the shelf at the shop is already full!
Tried to call; no VM option. :(
Tried to call the other day; I'm ready to part with a few of these.
Got four ready for you John
Tried calling again.
USPS Tracking Number 9500 1107 2786 0095 4544 85 - you should have your new vacuum advancer Tuesday.
