SOLD NM-97 40th anniversary 80 series
Year
1997
  1. 80 Series
Mileage
186000
Color
rgb(72, 62, 62)
So once again, the 80 is back on the market. I have found a diesel 80 I would like to purchase , which means I must continue thinning out the herd. I will be pulling off the rear bumper , replacing with a stock one, removing the drawer system, I will post more pictures soon , let me start off by answering these questions - factory head gasket never been done , ZERO rust, and to my knowledge ZERO issues. It HAS been repainted I have built this cruiser to keep forever but plans change. As far as I know I’m the 3rd owner ,
97 land cruiser 186,000 miles
Not triple locked
2.5 OME Mediums front and rear with Dobinson spacers in rear (30mm)
New Cooper discoverer ST Maxx 285/75/16 on Bronze Method wheels
Slee short bus front , slee swing out rear with hitch
Custom drawer system/ sleeping platform
CDL switch installed
Apple play touchscreen radio
LED gauges ( d light works and N light sometimes doesn’t but usually does (loose LED?)
Scanguage 2 on steering column to monitor engine temps
All electrical work inside however windows are slow to roll up and door locks are getting weak especially in rear , they were pulled apart and rebuilt but slowed down again
Headliner 7/10 with one weird burn / cut form PO
Seats have seat covers in front , seats 5/10 was looking for WRX seats to put in
Stock speakers with stock amp bypassed with new Apple car play radio
Driver mirror doesn’t work , zip tied in back to keep it firm
Weather tech floor mats all the way around
New fuel Fump and fuel pump relay
Birfields fully rebuilt passenger side with wits end Knuckle savers or whatever they’re called
OEM starter
OEM belts
fan clutch rebuilt with Toyota Fluid
Valve cover gaskets , spark plug gaskets , half moons , oil pump gasket with new wits end screws
Transmission been rebuilt with aftermarket shift kit and new torque converter
New idler puller
Plugs
OEM wires
New Battery
P401 and 402 fixed with resistor bypass trick
Dizzy OEM
Dizzy O ring
T stat
Flushed rad
PHH done
Snorkel
Roof rack ( home built but very sturdy)
Light bars , reverse lights on roof rack cheapos but work for me
Hi lift
Fresh paint ( Macao paint ) 1B2 antique sage pearl factory color , 40th stickers removed and sold to a mud member ( stupid to do I know )
Ih8mud charcoal canister fix
5% tint all the way around
Valve cover gasket
I will continue to add more as I remember and look through files .
19000
Pictures to come . Please serious inquiries only.
if you have any questions please ask them here for people to see , and DM if legitimately interested. I’ve had a lot of tire kickers recently .
