Nitro Xtreme Diff covers for Semi Float Landcruiser! FJ40 FJ60 FJ62 FJ80!
Letsgomoreplaces
Gear & Axle parts for ALL Toyotas new or old...
Washington
Website
www.letsgomoreplaces.com
Nitro Xtreme Diff covers for Semi Float Landcruiser! Now in stock!
As many of you know the factory stamped diff cover on the Toyota Landcruiser 9.5" semi-float rearend is little to be desired. They are thin, rust easily and dont adequately protect your expensive diff parts from damage. Since these are sort of the oddballs, none of the common sources make a diff cover for them.
The problem has now been address the new Nitro Xtreme Diff cover. Already a staple in the offroading community, the Nitro Xtreme cover is now available for Toyota's only application that utilizes a removable cover. Replace your dented rusty cover with a thick beefy aluminum one.
-Made in USA
-High strength Aluminum will not rust, also helps dissipate heat prolonging differential life.
-Extremely thick, will not dent, Cast gusseting to prevent being crushed in the rocks.
NP COVER-TLC $139
9.5" TOYOTA LAND CRUISER REAR DIFF COVER. FITS SEMI-FLOAT MODELS ONLY.
-USA FJ40, FJ55, FJ60, FJ62, 91-92 FJ80, SOME 93-94 FZJ80
-Some INTL MODEL 40, 55, 60, 62, 70, 80
Available for purchase through Landcruiser shop of your choice.
FINALLY!!!
Once I get a little cash, I'll need some
Diff covers
This is the only product that made me ALMOST wish I had a semi float diff to put one on!
Because some usdm 93/94 fzj80 are semi float. Also some international models.
How does this fit "some" fzj80's??
I can't see how it would fit mine.
