ARCHIVE Nitro Solid Pinion Spacers
Cashmere WA
Website
www.justdifferentials.com
Have you heard of a "Solid Spacer upgrade" for pinion bearing preload, but not really known why you should do this when replacing gears? We've made this short video to help explain why we always recommend a Nitro Gear & Axle solid spacer when available instead of a crush sleeve for setting pinion bearing preload.
Click HERE to view the video.
Solid pinion preload spacers (Solid Spacers) replace the traditional crush sleeve in many applications allowing you to remove the pinion nut and replace a pinion seal without losing pinion preload.
The spacers are installed with shims to achieve the correct preload setting and preload cannot be compounded by over tightening the nut or over-crushing the crush sleeve. Solid spacers also prevent pinion preload loss over time, adding to the longevity of your differential parts.
We stock spacers for Jeep JK's, virtually all Toyota's and many other applications. If you have any questions, need a quote, or would like to place an order please call us at 866 349 6801 or email us at: info@justdifferentials.com
Solid Pinion Spacers are still one of our most popular upgrades. They absolutely make sense when building a high performance diff assembly for any application. Check out the video link below to understand why you should make this upgrade whenever possible.
You can always find them on our website or if you have any questions about you can call us at 866 349 6801 or email us at info@justdifferentials.com and we will help you out!
