For Sale Nissan Frontier expedition ready
I have a 2000 Nissan Frontier 4x4, 5 speed V6 for sale. It is a single family owned truck with all records.
I built this truck up for a trip to Alaska and though I took the trip personally the Nissan ended up staying home due to two members dropping out at the last minute :bang: My Dad's best friend from high school and I did the trip together instead in his Dodge diesel crew cab with a Livin Lite truck camper he specifically purchased for this trip, 12,000 miles from York Pa. to all over Alaska & Back :steer:
I started the build in the spring of 2012,
3" lift,
extendable shackles,
front diff drop down bushings,
Bilstein shocks,
took it to Stengel Brothers in Allentown Pa. where they added proper leafs to the rear in addition to the $1300 suspension lift for increased load capacity,
Has new stainless brake lines,
5 Dick Cepek steel wheels with 5 BFG MT's 31x10.5's,
heavy duty skid plates,
ShRock Works rear bumper & rock sliders,
ARB bumper,
8000# WARN winch,
Defender roof rack,
IPF lights not yet wired up,
new windshield,
Safari Snorkel,
K&N filter,
Cobra 75 WX ST remote mount CB radio,
Firestick antenna and spring mount... etc...
I finished up this spring by removing the top of the engine, checking everything from cylinder walls & pistons, replacing all seals, gaskets, knock sensor, belts, timing belt, tensioner pulley, various hoses, radiator, cap, water pump, thermostat, distributor unit... Replaced front axles, sway bar bushing... more bushings... new engine mounts, new transmission mount, new drive shaft carrier bearing, entire new center link, new AC return hose and system charge... Have all four door window rubber's new in bags, 2 front window felt strips new in bags... etc... With the base value of the truck, all mods and parts replaced it would cost over 14k not including any labor to build this truck. The truck is currently located in Allentown Pa. I am asking $12,900. Feel free to call if interested, 610-360-4375. Thanks, Grant
Urban wheeling...
Parents neighbors love when I come home for a visit... & a shot of Alaska for entertainment value... :D
Issues
The current odometer reading is 153,700ish, issues... the ABS light is on due to sensor wires being disconnected/torn out @ the rear axle, the trans will pop out of 3rd gear if you slack up the drive train and do not keep a finger on the shift knob which is an issue that I was going to address the next time it needs a clutch. It has rust spots and one hole in rear bed where a bed liner sat for over 12 years which I haven't bothered to fix since I was planning on fabing up an aluminum flat bed for it. The interior is in clean and overall very good condition, I'll try and get some pix of it soon. Other than that it has been garage kept & detailed for most of its life while my father, who is a 71 year old dentist, owned it since new :D
Forgot to add that there are a few body scratches and a baseball dent in the top of the driver side front quarter. Other than that I drive this thing daily.
