SOLD Chapel Hill, North Carolina U.S.A. - 2010 Nissan Xterra Off Road Auto Trans (mod'd with trail damage)
Chapel Hill, North Carolina United States
October 28th 2024 Slow speed wheelin', rolled on to driver's side on Daniel at Uwharrie National Forest, recovered with a winch from a good samaritan and was able to finish the trail and drive home. Oddly was not negotiating a super difficult section, just got frustrated and went a bit too aggressive and tippy. Currently has 190,338-miles on odometer and is driven/wheeled occasionally. Have been replacing parts as I can procure them and updating this thread as repaired.
Asking $3,900 with all parts included.
Bad:
-cracked windshield (hood flew up when I got on freeway; thought it was latched)
-bent Hood; latches properly when slammed closed
-bent and badly creased driver's front fender, front door (have replacement door pending installation), rear door
-broken driver's side rear door glass, both rear quarter fixed glass broken; janky but very effective and water/wind-tight repairs with Dynamat Extreme
-windshield wiper motor and/or linkage broken and repaired (probably from hood flying-up)
-moderate trail damage on passenger side
-driver's side-view mirror broken-off and replaced
-driver's tail light lens broken and replaced
-both side curtain airbags deployed so would maybe need replaced and module re-flashed, as well as headliner repair
-antenna bent and repaired
-airbag light "on" due to side curtain airbag deployment; front airbags did not deploy as speed was very low and no front impact
Good:
-White Knuckle Off Road sliders in excellent shape and worked great for recovery
-33" BFG KM3's x 5 (pizza cutters)
-All Dogs Offroad (ADO) Enhanced Fox Extended Travel Lift Kit with ADO Recessed U-Bolts and Parabolic Leaf Springs
-ADO Rear Diff Breather
-OEM Nissan Electric (switched) Rear Locker
-Nissan ABLS (excellent traction control system means you barely need the rear locker)
-Hill Descent Control (switched)
-JVC Carplay / Android Auto (wired) head unit
-all maintenance current as well as predictive maintenance completed (heater hose fittings and radiator)
-all lights including signal lights function properly
-new TPMS Sensors, Radiator, Water Pump, Serpentine Belt, Idler Pulley, Heater Hose Fittings (metal not plastic)
-clean Carfax
-clean North Carolina title in-hand
-runs and drives great
Purchased in Garner, NC on July 17th 2023 at approximately 185,688-miles.
VIN: 5N1AN0NW9AC521068
NEXT OIL/FILTER CHANGE: 194,854 or by 14APR24
NEXT TIRE ROTATION: 193,467
NEXT AIR FILTER: 200,978 or by 01AUG24
NEXT CABIN AIR FILTER: 215,978
TRANSMISSION FLUID CHANGE: 215,989 or by 04AUG25
NEXT TRANSFER CASE: 216,032
NEXT GEAR OIL CHANGE: 215,989
SPARK PLUGS: 290,993
SERPENTINE BELT: 217,840
RADIATOR FLUSH: 287,840 or by 17MAR29
NEXT BRAKE FLUID: 14AUG25
Motor Oil (5.4 qts/22-29 ft/lbs): Valvoline Synthetic Blend High Mileage 5w30
Oil Filter: Nissan 15208-9E01A
Oil Drain Plug: Z1
Spark Plugs: Nissan 22401-ZE01B Iridium double tip
Air Filter: Beck Arnley 042-1685
Cabin Air Filter: Bosch P3602WS
Transmission Fluid (10.9 qts): Valvoline Full Synthetic Import ATF
Transfer Case (2.1 qts): Valvoline Full Synthetic Import ATF
Brake Fluid: Bosch DOT 3, 4, 5.1
Coolant/Anti-Freeze (2.75 gal): OEM Long Life Blue Coolant (Antifreeze) - 50/50 Pre-Mixed
Front Differential (0.85 qts): Valvoline Full Synthetic 75w90 Gear Oil
Rear Differential (1.7 qts): done by mechanic
Refrigerant: R134a
Serpentine Belt: Nissan 11720-EA200
Tires (Front/Rear psi, Spare psi): 255/85 16
Key Fob battery: CR2025
Wiper Blades: front 24” / 18” rear 12B”
MAINTENANCE PERFORMED:
05MAR25 190,338
-Replaced Driver's Seatbelt with OEM Nissan Part No.: 86885-ZL08C BELT ASSY-TONGUE, PRETENSIONER FRONT LH
-Replaced SRS Airbag Controller and Side Curtain Airbags takeoff parts-Replaced Driver's Seatbelt with new Genuine OEM Nissan part
-Replaced both Rear Doors with takeoff parts
-Replaced Fuel Door with takeoff part
(Nissan Parts Deal $385.14, FB Marketplace $770.00 Total= $1,155.14)
14OCT24 189,854
-Changed Oil and Oil Filter with 5.8 qts Valvoline Synthetic Blend High Mileage Max Life 5w30 and Nissan 15208-9E01A oil filter
-Removed only 5 qts Engine Oil
11APR24 188,740
-Installed new Rain-X Latitude Water Repellency Wipers (front) and Rain-X conventional (rear)
09APR24 188,735
-Installed new White Knuckle Off Road Rock Sliders after priming with Self-Etching Primer and painting with Hammered Black
(White Knuckle Off Road Products $911.55)
22MAR24 187,915
-Replaced all TPMS Sensors with BH Sensors RDE058V21
(Rock Auto $142.46, Alfa y Omega Tire $87.60 Total= $230.06)
21MAR24 187,888
-Recall Code PC945 Drivers Airbag Emblem (NHTSA 23V-067) inspected and advised no replacement is required
(Michael Jordan Nissan)
17MAR24 187,840
-Performed Cooling System Super Flush with approximately 12-gallons Distilled Water and 2 x Liquid Moly Radiator Cleaner, and Rislone HFL400 Hy-per Cool Radiator Cleaner and Super Flush
-Flushed Heater Core with low pressure hose water, Prestone Radiator Flush and Cleaner, and 1-gallon Distilled Water
-Replaced both Heater Core fittings with Z1 VQ40 Billet Heater Hose Inlet and Dorman 626-598 Engine Heater Hose Assembly
-Replaced Thermostat with Aisin THN007 and OEM Nissan Gasket 13050-ZA000
-Replaced Coolant Temperature Sender/Sensor with Beck/Arnley 1580606
-Replaced Serpentine Belt, Tensioner, and Idler Pulley with Continental K49394A
-Replaced Radiator with Koyorad A2807
-Replaced Radiator Cap with OEM Nissan 21430-1P107
-Replaced Coolant/Antifreeze Reservoir Cap with OEM Nissan 21430-1P111
-Filled Cooling System with approximately 2.5-gal OEM Nissan Long Life Blue Coolant (Antifreeze) 50/50 Pre-Mixed
-Changed Engine Oil with approximately 5.4 qts Valvoline Synthetic Blend High Mileage 5w30 and OEM Nissan Oil Filter 15208 9E01A
-Installed Z1 Off-Road Stainless Steel Magnetic Oil Drain Plug and OEM Nissan Crush Washer
-Installed OEM Nissan SRS Airbag Control Module 98820-ZL19A
-Replaced Odometer Reset Knob with OEM Nissan 24829-9CA0A
(Parts for Nissans $50.41, Z1 Motorsports $172.35, Rock Auto $273.44, Amazon $36.43, Quirk Parts $356.77 Total= $888.40)
19DEC23 187,716
-Multi-Point Inspection
-Parking Brake Adjustment
-SRS solid “on” Airbag Light Diagnostic
(Choice Auto Repair - Raleigh $308.57)
19DEC23 187,680
-Passenger-Side CV Axle (Duralast Gold CV Axle 10341N) replaced due to Uwharrie trail damage
-Wheel Alignment
(Sanders Automotive - Pittsboro $493.09)
21AUG23 186,101
-Passenger-Side CV Axle Replaced
-Wheel Alignment
(Pep Boys - Chapel Hill $587.72)
20AUG23 186,081
-Wheel Alignment
(Pep Boys - Chapel Hill $118.23)
*Advised Front-Passenger CV Axle Boot is leaking grease; possibly due to using reciprocating saw while cutting bolt
18AUG23 186,032
-Installed All Dogs Offroad (ADO) Enhanced Travel Lift Kit with Fox Shocks, Eibach Coil Springs, ADO UCA’s, ADO Parabolic Leaf Springs
*Damaged Steering Shaft U-Joint Boot while installing driver’s-side UCA
-Treated undercarriage with Rust Converter and painted matte black
-Installed ADO Rear Differential Breather Extension
(Purchased Lift Kit and Breather Extension from All Dogs Offroad $3,065)
14AUG23 186,032
-Replaced stripped Transfer Case Drain Bolt with Nissan and changed ATF; just shy of 1 qt dark brown ATF came out, refilled with just shy of 2 qts Valvoline Full Synthetic Import ATF
-Bled Brake Fluid with Motive Power Bleeder and topped-off with Bosch Brake Fluid DOT 3, 4, 5.1
10AUG23 186,001
-Replaced Nissan Multi-Function Switch (clock spring) 25560-9CH4D
-Replaced rusted Gate Striker and Bolts with new Nissan Gate Striker 90570-5Z000 and Bolts (Screws) 80599-AZ00A
-Steering Angle Sensor OBD codes P1143 and P1163 cleared and sensor re-learn performed
(Sanders Automotive)
06AUG23 185,993
-Changed all 6 spark Plugs with Nissan 22401-ZE01B Iridium double tip
05AUG23 185,993
-Restored headlights with 3M Ultra Headlight Restoration Kit
(JD)
04AUG23 185,989
-Changed Oil and Oil Filter with 5.4 qts Valvoline Synthetic Blend High Mileage Max Life 5w30 and Nissan 15208-9E01A oil filter
-Drained a little less than 4 qts dark brown ATF from transmission. Filled with 4 qts Valvoline Full Synthetic Import ATF and checked dipstick level as full
-Changed Front Differential Gear Oil with approximately 0.8 qts Valvoline Synpower Full Synthetic 75w90 Gear Oil
(JD)
02AUG23 185,981
-Installed JVC KW-M780BT and wiring harness
(JD, purchased from Crutchfield $468.55)
01AUG23 185,978
-Rear Axle Seals replaced
-Rear Wheel Bearings replaced
-Replaced Rear Brake Rotors and Pads
-Replaced Parking Brake Shoes
-Changed Rear Differential Gear Oil (only approximately 1-pint remained before changing)
-Drilled/Cleaned-Out Rear Axle Differential Breather
(Gaines Automotive $1,100.12)
-Replaced Tailgate Hatch Gas Shocks with OEM Stabilus
-Replaced Cabin Air Filter with Bosch P3602WS
(JD)
-Engine Air Filter replaced with Beck Arnley 042-1685
20JUL23 185,967
-Installed 5 BF Goodrich Mud-Terrain T/A KM3 LT255 85 16
(Purchased from TireRack $1,820.20 and installed by Alfa y Omega $175.20)
-Installed Battery Hold-Down Clamp
(Purchased from Amazon)
I’ve got a running 2007 dark blue Xterra S up here in VA
WAS going to be my project wheeler before I got my LX470 back
If it’s of interest, I can get pics to you if you want to think about keeping yours and grafting mine.
Thanks for reaching-out. So far I am just wheeling it as is. Got the radiator/light cradle straightened a bit allowing the hood to latch. Took it to Uwharrie again and did Dutch John with no issues. Would probably consider taking parts: driver's-side doors, hood, SRS curtain bags, driver's seat belt from a Silver Xterra.
Adding some updates pictures after replacing some damaged components:
Replaced Driver's Side Rear Door (transferred better door card and speaker from old door) Door and Window function as designed.
Replaced Passenger's Side Rear Door (transferred better door card and speaker from old door) Door and Window function as designed. Has some aftermarket window tint which I will remove.
Replaced Driver's Seatbelt/Pretensioner with new OEM Nissan.
Replaced SRS Airbag Module and both Side Curtain Airbags.
