crushers
post ho
tenetively:
the next run will be a tight technicale trail, early start and long day.
either modified rig or stocker with no regard to possible (probable) body damage.
prefer 33s or bigger
locker in the rear a good idea
WORKING winch is recommended
spotting will be required in many spots
(possibility of a sleep-in-your-rig overnighter)
bug spray and bug netting STRONGLY suggested
deep a rough holes
rock crawling
TIGHT threading-the-needle
possible off camber situations
possible kissing of trees and rocks
<if your truck is a pretty truck, this is NOT a trail for you>
to make this happen i will require MINIMUM 3 rigs and i would like to know ASAP since we have to work with Jeremy on the date.
this trail will be good for those that want to learn tech wheeling vs "second gear and pin it" wheeling.
deep a rough holes
rock crawling
