New to me BJ74 with some questions
Hello,
The battery terminals look hacked. I think the fusible links are missing, but it is better to have a closer look.
Toyota did not consider a turbo timer for both the 13B-T and the 2L-T. The user was expected to let the engine running until the temperature stabilized, which took 5 to 10 minutes according to the user's manual, and that only after heavy loads, like driving at speeds over 100 km/h for prolonged periods.
A quick test may help.
Start your engine. If it does within 20 seconds (or less) of cranking the starter, your electrical system is in good shape. If it takes longer, or needs a second cranking, something is drawing current. This is not a definitive test but provides a hint.
Have that timer and all its wires removed, and then try cranking again. Cranking time before engine start should decrease. If it does not, check again.
There are only a few common ground points for the whole electrical system. Locate them using the service manual diagrams, and remove every non-factory ground.
It is good practice to follow the wire harness. Power for non-OEM equipment is often drawn from a harness wire, which usually involves cutting and splicing, sometimes crudely. Find these hacks and eliminate them.
Power is also obtained from the battery terminals, in much the same way. Delete these direct taps as well. Be careful.
Do the cranking test as you remove wiring. If startup time decreases, things are going well.
Hope this helps.
Juan
Problem seem to be solved. Voltage regulator died and we had to replace it. Alternator was serviced and I put everything back. Now the oil pressure gauge does not work. Any ideas? Wrong pipes on wrong connections?
Perhaps the wire got knocked off the sending unit when the alternator was being serviced?
Right side of engine block, directly in front of the engine mount. If the vehicle has air conditioning it will be hidden between the front of the engine mount and the back of the A/C compressor.
I hope that's all it is. The sender is in a bugger of a place but the wire is not too bad to deal with.
You may have a better visual on it from below looking up.
I put the rack on. It is a JDM Abaworks I acquired when I visited Japan in 2010. I packed it as luggage...:grinpimp:
It is mounted via Thule artificial rain gutters attached to the FRP with 8mm nutserts. The screws that attach the bracket to the top are Tundra bed tie down screws.
Hold the bracket up where it looks right.
Mark the holes with a suitable instrument.
Break for a beer.
Drill holes in the diameter specified by the insert manufacturer.
Set the inserts in the top using the tool/procedure specified by the manufacturer.
Break for a beer.
Bolt the brackets to the top.
attach the rack of your choice to the brackets.
Break for a beer.
Required tools/supplies.
Two Thule artificial gutter kits (toss the fasteners, they suck).
Eight 8mm Nutserts (maybe an extra or two if you jack one up).
A pencil or Sharpie or similar.
A drill and bit.
A nutsert setting tool (looks kinda like a riviter).
Eight 8x~20mm bolts of your choice.
Twelve beers.
A drill and bit.
Twelve beers.
Dan I realize you constantly strive to provide useful information to the 'MUD community but in the above case isn't the beer on the wrong end of the project?
If you read the instructions you will note that they appear throughout. Every third step.....:)
This is the only file photo I have with the inserts sans brackets.....
Charging issues sorted. This afternoon the clutch decided to disappear. Doesnt want to,shut off either. So I presume its the clutch booster.
Is the pedal effort quite high?
