crholliday
Frisbeetarianist
More like newbie mechanic poseur wannabe questions. My '94 is really running well except for a couple of things:
1. Weird idle. When I first start it in the morning it is around 1750+ for the first 90 seconds then every 20 seconds it drops 100 revs until it gets to about 650. If I have run it within the last couple of hours sometimes it will startup with an idle around 600 then drop to 400 until it runs for 10 minutes or so. I assume this is the TB needs to be scrubbed.
2. The ride is pretty rough. I see that most everyone changes their suspension. I am wondering if the characteristcs that mine displays are normal or if they are rough. I feel every chatter that I roll over at 35 mph or less. My shocks may be original or they may be worn. The POs both took pretty good care of the truck but it may just be an age thing. Or I could be a creampuff about it.
So the questions I have around this are:
- Can a rookie remove the TB without the FSM and how much time would it take? If the FSM is really required then what kind of time would it take to remove and clean with the FSM?
- What characteristics would improve by going to non-lifting OME shocks front and rear (the kind that work with the OEM springs)?
- Unrelated question: I drove through about 30" of water this past weekend to get out of a flooded campsite in Arkansas. Is there anything that I should do as PM after a dip like this?
Thanks,
Chris
Thanks,
Chris
