For Sale New Orleans, LA: 2000 LX470 - Mild build/TRD supercharged
Year
2000
  1. LX470
Mileage
234999
Color
White
More about my 2000 LX470,
JT6HT00W4Y0124600
Currently has 234,xxx miles. I picked up a 200 series for a daily driver so miles will increase slightly.
Clean exterior except for minor dings on the passenger fender. Seems to have all original panels and no paint work.
PO had a new transmission installed at Lexus in Orlando @ 164,863 miles, checked history on lexusdrivers
It spend most of its life in Austin and then the southern gulf coast. No cancerous rust.
I installed the TRD supercharger @ around 200k miles 1/2017. I was a senior tech @ Lexus.
I also rebuilt the starter at that time and installed a belt tensioner. New oem fuel filter. New AFE air filter. OEM parts only, otherwise mentioned.
I replaced the plugs with a step colder Denso plugs and also installed a TRD thermostat.
Replaced the radiator with a Denso unit and Toyota coolant as well. Also replace the heater T's with oem ones. (All that was mentioned thus far was done around 1/2017 @ 200K)
Retrofitted some SC430 projectors with clear lenses. It appears stock but the light output it probably better than most vehicles on the road. 2/2018
New OEM ABS unit ($$$). 1/2019
Ultrasonic fuel injector cleaning by Mr. Injector. 4/2019
Engine oil/trans fluid change(Pennzoil Plat/Maxlife ATF). 4/2019 and 221k
Since the last update, 6/27/19, I've done the following:
Front wheel bearings with Timken units
Front and rear rotors. Hawk LTS(front) and Powerstop Z36 (rear)
AHC delete w/KONI Raid adjustable shocks, Swayaway torsion bars, OME 863, and an alignment.
ARB Deluxe 2003+ front bumper and MetalTech 4x4 sliders.
Engine oil/trans fluid change(Pennzoil Plat/Maxlife ATF). 9/2019 and 228k
I have four 295/70/17 Toyo R/T mounted on Konig Six Shooter 17x9 +25 (9/2019) and a 295/75/16 Toyo ATII on LC 16s for the spare. The new wheels/tires has 5,000 miles as of 2/2020 (Mainly from trip to Ouray, back to New Orleans, then to Cape Canaveral, and back home to New Orleans)
Lseat front leathers. 11/2019
Serious case of cold feet. May try to relist at a later date.
I'm located in New Orleans, Louisiana
Very nice. Wish I had a little more money. How much power with the TRD Supercharger?
Did the konig / FN wheels clear the front hubs without modifying?
looks like a well cared for LX
GLWS
Nice rig! This is the second one I've seen with a SC today. Other than more hp's, do you get any increase in mileage?
It's pretty comparable to non supercharged ones if you're careful not to lay into it.
Bump.
I shouldn't get another vehicle but I'll entertain trade offers. Something fun to drive, must have a manual transmission, and preferably RWD. Sorry no Miatas lol.
Or a Harrop TVS2650 Stage 1 kit for the LX570 + cash!
