I have a new mono amp and new 10" JL W7AE sub coming in. I have not replaced my factory head unit or factory amp yet. I have replaced all door speakers. I plan to replace the factory head unit this spring/summer with the new AVIC-X940BT
I plan to install the mono amp in this location like BBQ did:
http://i178.photobucket.com/albums/w252/BBQRidge/IMG_3322.jpg
But that is about the extent of my expertise. So, I hope one of you can help me with some questions:
- Since I will be connecting this to the factory system at first and then to an aftermarket unit. Where do I run the signal to the amp from? Is there a place on the back of the factory head unit I should tap into/plug into?? Should I take the signal out from the stock amp to the factory woofer and use that??
- Power to the Amp - I have run a fuse panel to the factory jack location. Can I tap into this or should I run power directly from my 2nd battery?
- How do I make sure the amp doesnt have a continuous draw from the battery even when power is off? Will this be in the instructions?
- BBQBOY - what are you using to secure your amp in that picture above?
- Anything else I should know before taking this on?
