Did you ever get your charcoal canister replaced?? How do you tell the one you have is bad? Why can't you use a coffee can with briquets in it and save for the BBQ?
Just wait for the mining claim. That will prove the success.I figured mine was toast because of the amount of tank pressure and at altitude fuel was boiling off in the tank. I changed it out with the GM cheapo the day before the bacon run and had no pressure problems up there at all
Do you have a shroud?Sometimes its the little things. No more **** ass flex fan. Thank you again Chris! New oil and it works as it should.View attachment 1046730 View attachment 1046734
Must have used an SOS pad on that thing!!Glad you could use it.
rerouting =Got my rear spacers in last night with about a total time of 20 minutes? and did some rerouting of the tail pipe so I quit dragging it on everything.
sawzall
of course! it is a little more up out of the way thoughrerouting =
Code:sawzall
You have a 3FE, right? If you are going to swap the trans for a manual, you might as well pull a TBI 5.7, NV4500, NP2?? out of a Chev and swap it all over...
