Does anyone have the part number for the non heritage rear springs? I’m looking to get a set
Right 48231-60A20Does anyone have the part number for the non heritage rear springs? I’m looking to get a set
Seconded. Get the firestone airbag kit and put those in when you swap springs. Others just use a bike tire pump to get them dialed in. It moved to the top of my wish list yesterday after the 200 had tailgating duty at the Cowboys game. 7 grown men and gear made it sag like crazy.Right 48231-60A20
Left 48231-60B11
Note that they sag significantly when loaded.
HE has thinner wire and similar wraps so should be the softer of the two.Do these sag worst than the HE rear springs? I didn’t realize the spring rates were softer for the regular springs vs HE.. always thought it was just a longer spring used.
Showing different rear coils with/without 3rd row. Left/right coils will be different heights to compensate for KDSS. I can’t imagine the 3rd row/non 3rd row coils are more than a few mm different in height. Those rear seats don’t weigh much. And wouldn’t the Base coils be stiffer or longer than the HE with no rear seat? I’d assume Toyota was designing for a consistent geometry and natural frequency with and without the rear seats.Anybody show a different part number for the HE? I've never heard of them having a different rear ride height.
Not sure where I got it but my notes show stock 3-row coils being 170lb/in. And as mentioned 2-row coils have thinner wire and same number of wraps, so would be less rate.Showing different rear coils with/without 3rd row. Left/right coils will be different heights to compensate for KDSS. I can’t imagine the 3rd row/non 3rd row coils are more than a few mm different in height. Those rear seats don’t weigh much. And wouldn’t the Base coils be stiffer or longer than the HE with no rear seat? I’d assume Toyota was designing for a consistent geometry and natural frequency with and without the rear seats.
If you’re looking to lose a whole inch, a steel rear bumper and tire carrier might be the best option. I’d estimate the rear coils to be somewhere around the 220lbs/in range, so you’d need 440lbs over the axle, or maybe 300lbs out past the bumper to drop an inch.
A bumper might take an inch but will also make the rear wallow around on stock springs and dampers.
I measured my HE when new While doing a little flex test.
Center of wheel to inside edge of fender.
Front: 20”
Rear: 21-7/8”
*Drivers & Passenger side were exactly the same and after the fork test thing.
FWIW, my 3 row HE measures the same as yours within 1/8" all the way around. Anyone have the Base measurements?
Rear coil wire measures 16.9mm if anyone is counting.
forum.ih8mud.com
Innnteresting! Thanks for the link.![]()
Heritage vs base REAR springs - HE & 2020 base owners, could use your help
Hello all, You may have noticed some discussion on the rear of 2020 HE 200s seeming a bit higher than their base siblings. At first people assumed this was due to the removal of the third row and necessary hardware (3 seatbelts, folded seat anchors, etc), but @Eric Sarjeant eventually confirmed...forum.ih8mud.com
