I have worked on a ton of vehicles and IMHO the Aisin clutch is the best design that I have seen. Have never worked on a ’100 clutch, but have done most other Toyota clutches. In my experience the clutch is a great design, compromised by thin fluid, probably to make a smooth, quiet running motor and eek out every CAFE fraction of a mpg possible?
The thin fluid is just adequate for normal operation. When run harder than normal or in hot temps, it’s sheared hard, this heats the fluid, causing the viscosity to be reduced, lower viscosity has less drive/shearing ability, so it has to work harder, so it gets hotter, repeat, until the fluid is dead. It’s not “an ’80 problem”, it’s common among all of the later model Toyota’s that I have worked on.
By changing to higher viscosity fluid, the fan has much more drive, so when it comes on it does the job and turns off, much shorter cycles. The fluid is less stressed and lasts much longer. The main benefits are, reduced A/C vent temps when idling, higher ultimate cooling capacity to overcome any “oops moments” and longer fluid life.
Swap in some 10,000 cst fluid and report the changes, my bet is you will notice a big difference.
I don't agree with adjusting the valve colder, don't want the fan engaged more often, want to more effective when it's needed. Adjusting the valve cooler is like installing a colder thermostat, it starts working earlier, more often, but doesn't add any cooling capacity.
