Howdy Land Cruiser Fans. 1st thread I've started here.
95 LC. Stock. 2 inline cats.
405,000
Had shop install new oem exhaust manifolds, magnaflow y-pipe and 2nd cat, oem muffler a d tail pipe. Reused newer upstream O2, brand new 2nd O2. Both oem.
Started making noise/leaking in 2 days less than 100 miles.
Gasket between 1 connection at y-pipe to manifold and gasket between 2nd cat to muffler are blown. They tell me it's running very hot. Point to the blueing of the new y pipe. They say this is why the gaskets are blowing out and leaking. I don't know what to make of this info. The original exhaust did not leak. I replaced it just to di it before I had a problem. Ooops.
The CEL is on. I have tried the paperclip but don't get a code.
I am hoping to drive to Massachusetts from Ohio in a day or two.
What can I make of this?
Please give me advice as what to do now.
Edit.So, I should have waited before posting. Probably just loose hardware. Going to double nut the cat flange studs. Also, going to use studs and double nut the y pipe flange to .maniflods. I'd delete this whole post if I could from my phone .
Thanks in advance,
Ed
405,000
Thanks in advance,
Ed
