Yep, they just cut it off.resonator you dont need!! just cut the pipe and save yourself a couple of pounds!
Pick up the pieces and look for a part number.Hey all! This is a very old thread, but I figured I would ask….
I recently came across one of these rear bumpers, and have loved having it.
The swing arm was a little loose so when I pulled the cap to tighten it up, the bearing inside was toast, and actually fell apart when I pulled it out.
By chance, does anyone know the measurements on the bearing so I can replace it?
Thanks for any help!
Just one. The swing out has a gig plastic insert that the race rests on.Kennyg, did you use 2 sets of races and bearings for the one swingout, or just 1?
KennyG, I’m working on my swing outs this week and those castle nuts are huge! 37mm is what I measured. Where did you find a socket that big or did you get them out another way. I can’t even find castle. It’s in the 37mm flavor online.Just one. The swing out has a gig plastic insert that the race rests on.
Grab a punch and tap it loose! You would need a super thin wall socket to get that to work. Just make sure its tight enough when you get everything re-assembled.KennyG, I’m working on my swing outs this week and those castle nuts are huge! 37mm is what I measured. Where did you find a socket that big or did you get them out another way. I can’t even find castle. It’s in the 37mm flavor online.
That's how I got it out. I need to pull out the 3 arm puller to get the arm off the spindle. I was just hoping this was a standard sized castle nut. It sounds like it's not. I can make due. Thanks for the reply!Grab a punch and tap it loose! You would need a super thin wall socket to get that to work. Just make sure its tight enough when you get everything re-assembled.
Also, if you are using a press and installing new races, Make sure to remove the plastic bushing before pressing. Mine is now slightly deformed.
Cheers!
Yeah getting it off the spindle was a work out. Took a lot of swinging and pulling to get it off. Also had the help of a floor jack.That's how I got it out. I need to pull out the 3 arm puller to get the arm off the spindle. I was just hoping this was a standard sized castle nut. It sounds like it's not. I can make due. Thanks for the reply!
