Jeez guys, thanks for all the input!! I got the tires at Costco, the tech was a little concerned that it wasn't the right size tire, but I convinced him they would fit fine. He then mentioned a couple of red flags. 1. The new size is 6% bigger and my speedometer would be off, so 75 mph on he speedo = 80 mph actual. Big deal I can handle that. 2. He said these were D rated tires for a truck and would fill the tires to the recommend pressure of 65 PSI, which he did. So it sounds like I need to bring the tires down to at least 40 PSI for a starter. I'll give it a try now!!!
Also 96K on the Michelins is a crazy amount of miles. I wouldn't have believed it but I check the odometer every time I do a repair. Though I was seeing steel belts popping though on the outer tread. Yikes!
Thanks again! Doug
Now where the hell is my tire gage.
65psi is not a recommended pressure, it is a MAX pressure.
