Hey guys! I'm replacing the driver side half shaft because of a worn boot and am getting stumped with the removal of the inner part of the shaft. According to the maintenance manual, you use a brass bar to tap it out but I'm having very little luck with that, in fact I'm having no luck. I've been beating on it and it won't budge at all. Should I just continue until it gives or try working it apart with a pry bar? Any suggestions would be very appreciated. Thanks!
). In the end I got it off and all put back together. Thanks for the quick responses fellas!!!
