So, as the above title says, I am in need of some advice. I have surfed the forums here, and in a few other sites and decided to call on the mud( seemingly better crowd of guys) and so far as I can tell no one has answered this question
One backstory first, I picked up a 92 80 series landcruiser for a wooping 400 bucks. A friend owns a shop and had a guy bring it in with a nasty knock. Said he ran it out of oil coming back from portland. His oil filter fell off. Fired it up real quick and it is diagnosed as a head knock. Got it home and took off the valve cover and every valve is extremely loose. Tightened the valves just a lil bit per valve(not the correct way, but taking out a hell of a lot of slop) and the loud knock became a quite knock. But a knock nun the less
since winter is coming I need a good 4x4. So my question....
Can a 2f regular (not a 2fe) out of a 62 be put into the 80? While the 3fe is being repaired I happen to have a 2f on hand and wondered about the complexity of doing a quick swap so I can drive it. I have a spare hood so I was thinking I of chopping up the current hood and doing a cowl like segment since the 2f block is a taller block then the 3fe.
Since I travel I happen to away from the beast atm, and my winter project is the 3fe so it will be going back into the 80
