Researched already, can't seem to find anyone with this issue exactly. Adding pictures for clarity (hopefully)
My hood was working fine. I opened it last weekend to check some things and welhen I went to latch it back down, it just won't latch.
What doesn't make sense to meis the mechanism. The cable release works. In other words, when the cable is pulled from by the driver side handle, (see pic1) the latch will move the swivel aside and release the hold on the main tooth.
But when the latch is just sitting as in pic 2, the hold from the top just smashes into the red x. and bounces off.
What confuses me is that I never had to pull the cable in order to close the hood, but it seems that that's the only way now to get the swivel seen in pic 1 to open so that the main tooth can come down far enough to latch
But even that doesn't work!!!! is there some trick to setting g the cable a certain way or what.???.I'm at a loss.
my issue isn't related to a malfunctioning latch per se, because I bought a replacement brand new and have the same issue..I un-installed the latch and moved it up higher thinking that would help but it's the same issue..
wtf!
any insight appreciated
wtf!
