Need Help with 2014 No Start-No Crank-No Click
colorado
I have a 2014 that l'm having a no start issue with.
New interstate AGM battery, but again two other charged batteries didn’t work. Key fob unlocks and car works as normal from 120’ or so except start button has green light, but won't click, start, or any noticeable result from button. Previous battery was 5 years old to the month, but same condition even after fully charging.
When I shift shifter, start button indicator light is green only on D and N, so i assume neutral safety switch is ok. I tapped on all relays but haven't replaced anything yet except battery. I believe this all started after stepdaughter left ignition in all night.
↑ 13
If you have a long brass drift, a hammer, and can get under the vehicle, you might try to tap the starter solenoid to see if it free's up.
I once had an old truck that came with a hammer for such purposes.
After replacing my starter I don’t see now this is feasible. Would love to see it done.
Following up with the fix. It was a relay in the fuse box in engine compartment. Labeled ST on the diagram and replaced with relay NAPA part # AR483.
That part # comes up as a blower motor relay. No big deal but how did you figure that out? Just crossed the old relay # over?
there are a lot of relays with the same exact part number. My Crank but no start was fixed by swapping a few of these until it worked. I think there are 6 or 8 identical relays, maybe more
Understood and maybe want to have one on hand. I can see how this could happen.
