Need Help (Wheel Base Out)
I recently purchased a 82 jf40 from out of state,since day one it has always pulled to the right. I've been messing with this issue for the last 4 months. The problem is the driver side wheel base measure 92" the passenger side measure 90 1/2", there a 1 1/2" difference. First I replaced the springs with HFS thinking maybe there were a missed match set, but that didn't do anything. I took it to a frame shop and they straighten the frame within 4mm which was diamonded, but it did not change the wheel base, it does drive a little straighter, they have no ideal what the problem is, maybe a bent axle housing. The weird thing if I turn left it will drive straight, but as soon as I make a right turn it pulls right. At this point I don't know what to do, could a bent axle be causing this, looking at the axle housing everything looks straight.
Any help would be greatly appreciated, Thanks
Are the military wraps on all 4 springs on the spring pins at the frame?
Any good frame shop can diagnose whats up........
I'm not getting any "CONFIDENCE VIBES" on the one you used.....
Take it elsewhere........
are the spring perches oem?
