Need help identifying two hoses (1 Viewer)
NC
These two hoses are leaking (at least I know the top one is) and I would like to know what they are. The picture is taken from the inside of the driver's side fender. Pretty steady drip. Thanks!
Transmission to trans cooler.
Make sure the power steering pump isn't dropping out the back down onto that area or lines, those look like the tranny cooler lines run from tranny to the cooler
Thanks. The PS fluid stays full but does leak a little at the reservoir to hose connection. These two hoses connect to metal tubes near the coolant block plug. They leak more when the engine is cold but less as you drive it more and at normal temperature
And the picture is from the rear of the front driver side fender
