Does the tire wear look fine even on the front tires? I would check your toe alignment. Have you actually measured the caster angle before installing the shims or afterwards? If you take it in for a front end alignment, they will give you a print out of the caster alignment and you can find out if it is good. I need to check my toe alignment after a summer of heavy off road use.
