Short version, I just recently bought an 87 FJ60(my first cruiser) with compression 150,150,0,78,50,150. I pulled the head off and it had a broken valve on #3(0 psi). I got the head totally re done with all new valves and springs. Threw it back on(the head was going to need redone regardless) now compression is 150,150,150,78,50,150.So my question is now what? Obviously the rings are leaking, but the walls look real good. I could pull the oil pan and change the pistons and hone the cylinders, but if I do that I might as well just pull it and change all the bearings too. Ideally, I would like to find a short block and rebuild it at my leisure so I can still putter around in it as it is. Then when I'm done I can just swap in my rebuilt short block. I can't really find one in this AO, do they pop up or am I going to have to drive 3 states away?What I really want is a 12H-T with H55F but I'll keep dreamin'.
