I've not been running my 80 much lately and have had it at the shop with a Deltran Battery Tender Plus hooked up all the time. Batteries hooked up full time in parallel. Every time I pop by the shop I check the batteries. Through the summer I noticed it was in charge mode more then I thought it should be (no loads). A week ago when I went to install an awning it was in storage mode. Started and moved the vehicle and when done I put it back, with the charger hooked up. Stopped by the other day and noticed the charger was smok'n hot and the batteries were at 12.50(ish). I asked my shop mate to keep an eye on it till he left and disco it if still the same. Couple hours later he texted that he had left and disco'd the charger. I went back the next day and checked both batteries while hooked up in the vehicle and they were reading 12.45.. Took the batteries out of the vehicle system and the right battery was now at 12.55 and left battery at 11.50 and dropping. Hydrometer test showed one bad cell. It is a NAPA house battery, about 5 years old.
I'll replace the battery with a standard auto battery as I have a trip coming up in a couple weeks with the 80, unless I can find a dual purpose 27F. I've got most of the setup to isolate the batteries (Blue Sea ML-ACR) and have contemplated adjusting the wiring so I have two standard 27 series RV batteries in place, whenever I get around to the install. Not to open this debate as is discussed on other threads; I've not decided if I want one battery completely free of load when the truck is not running, or split the load with all vehicle on one side, and house/extra loads on the other. The system will have at a minimum a 100 watt solar panel as well.
I've got two of the micostart batteries. This summer the diesel Dodge was deader then a door nail due to user error. Before the jump...nothing was working, not even a click on the starter relay. So I put one of the Anti Grav units on the left battery (it had been sitting for well over 6 months but showed full charge) and tried to start. Cranked a few revolutions then click click click. Waited a minute and tried it again...same result. It now showed three bars. Left it hooked up and put one of these on the other battery:
Mini Multi-Function Jump Starter The AL-JP16 had been plugged in for months. With both hooked up it cranked a few times and started.
I wonder if the micro battery that was plugged in till used would have done it on its own. (I did not volt meter the truck batteries before hooking things up, but after running for 4-5 minutes then sitting for a minute or two they read 11.3 and 11.4 so they were down quite a bit)
hth's
gb
