@vandir, $1050 or $910 or whatever you paid isn't horrible for a fuel pump replacement on a fuel injected car.
Fuel injected fuel pumps are typically located in the fuel tank, which makes replacement a matter of dropping the fuel tank.
Driving while you're low on fuel won't burn out your fuel pump. The fuel pump uses the fuel it pumps as a lubricant. As long as there is enough fuel to provide a constant supply of fuel to the fuel pump, it will be lubricated. But when you drive on empty and your fuel pressure struggles to suck up enough fuel to lubricate & keep fuel pressure (i.e.: "running on fumes"), you'll quickly burn out the pump.
When I was in high school, I had a Ford F-150. Being a high school student and getting 15mpg, I was too irresponsible to fill it up with gas enough & I was running out of gas all the time. Within 20,000 miles, I had burnt out the fuel pump & it cost $850 to get it fixed. This is almost 20 years ago, so yeah, $910-$1050 isn't bad.
Also: Mechanics always mark up their parts. They pay wholesale and sell to you at retail (or higher). They don't only make money off their hourly rate-- (and the number of hours they bill you for is usually inflated, based on the "book time", not the time it actually took them to do)-- they make money on parts too. If you bring in your parts, they might agree to install it, but they will tell you they can't warranty the work. That's standard business practice, and if you don't like it, I suggest you start wrenching on your own car.
