- Joined
- Jan 4, 2014
- Threads
- 94
- Messages
- 3,042
- Location
- Little Rock, Arkansas
- Website
- www.facebook.com
Being a longtime slalom skier, water and I have had a love-hate relationship. I came out to the truck this morning to head to class and I noticed there was a little water down in the passenger side footwell that had soaked into the speaker mesh.
At first I thought it was my air conditioning condenser(?) that was dripping because I've had this problem in the past. But then I looked up...
I snapped a few pics but didn't have time to fix it. I threw it in reverse and backed up my driveway to leave and about 2 cups of water dumped into both the passenger seat and my lap as it made it's way over to the drivers side. I park facing downhill at a very steep angle with the front right headlight being at the lowest position.
I figure the culprits are clogged sunroof drain hoses because I've also had this problem in the past but I wanted to get a few opinions from you guys. So, what do you think? I planned on doing a bit of PM this weekend (oil/filter change, replace tire that has puncture in sidewall, clean throttle body, etc..) and if I needed to add this to the list I will.
One last thing. After I got back home I took off the passenger door trim at the bottom as well as the cowl panel in the passenger footwell to expose all the electrical connections. Should I worry about these being harmed by the water?
I'm assuming as long as it doesn't touch the ECU behind the glove box I'll be fine. I appreciate any input!
