My LX470 AHC woes - Not a happy ending!
Please hang in there as this is going to be fairly long but I want to be clear about where I am in the process of fixing my AHC. I've learned a lot along the way but I'm still on the road to enlightenment!
First the facts:
2003 LX470 with AHC & 60,000 miles
Original symptom - Wouldn't raise to N or Hi but wasn't sitting on the stops
Secondary symptom - Eventually, the rear lowered to the stops, the front was within 1" of the rubber
I began doing my homework and have access to the FSM.
I removed the three sensors and they are fine with a good signal throughout their range of movement and no corrosion or leakage detected. I sealed them up and reinstalled.
I decided to replace the spheres on the damping force control actuators (because it's about that time) and I got them from Keith Bowers of B&B Syspension. They installed fine.
It took a good deal of work to get the air out of the pump and begin getting pressure but eventually I managed to do this. (If anyone wants to know the grizzly details I'll be happy to explain).
At this point I can read and reset codes blindfolded. I'm also using a digital volt meter, DVM, to monitor the hydraulic pressure at the pump.
I bled the fluid from all four accumulators and bled the height control accumulator just a little.
At this point I can put the selector in "L" and get the hydraulic pressure to spec and the pump turns off - so far so good. I then select "N" but the pressure can't get to the level required for "N". Upon selecting "N" the pump actuates, the pressure drops off somewhat (I presume that a valve has opened somewhere to allow fluid to flow into the height control accumulator) but the pressue never does get back to the maximum observed pressure that I had while in "L".
(Please don't tell me to just go to L and stay there!)
Finally, my questions:
How do you know when all the air has been bled out of the hydraulics?
I understand air bubbles etc. but what is the symptom of an AHC system with entrained air in the lines? The FSM is silent on this.
Finally, I can't find a specific procedure on bleeding the height control accumulator. Do I just use the manual height adjustment mode and bleed the height control accumulator just like the accumulators?
First the facts:
