Hello all, it’s been a while since I’ve posted. Just wanted to share a bit on my latest upgrade to my 68 FJ40. We finished the frame up restoration of this rig in 2018 and it has been a daily driver for 3, going on 4 years. When I restored it, I rebuilt the original 3 speed and kept the 3 on the tree. However, there were linkage issues (not surprised). The first year we were driving it, the rig got stuck in first, assuming partial gear engagement, with the end result a very very noisy first and reverse. Below is a picture of the carnage.
As you can see, putting miles on a noisy box may not be the smartest, but FJ40 owners are sometimes not know for what makes sense….right (LOL).
Part 2: Shortly after I finished the rig, I came across a Berens Hone-O-Drive overdrive as a barn find, it was in a box, complete with the transfer case replacement shaft. It was all there, with the planetary gear set in ‘Not ground to razor sharp teeth’ condition. For you that are not familiar with these units, hard parts are unobtainable. However, bearings, synchro rings and O-rings are….so it was rebuilt. In fact, for assembly and to make sure I had all of the hard parts, I used a Berens Hone Drive manual I downloaded from Mud (thank you whoever posted that…so long ago). Below is a picture of the overdrive guts prior to assembly.
Part 3: So once the the transmission started making noise, and since I have pretty much 2 of everything for the 68 FJ40, I cleaned up and rebuilt a second 3 speed, and a second transfer case using the Hone-O-Drive output shaft. The only hard to find parts for the 3 speeds are the needle rollers in the reverse gear and the cluster, no longer available in USA (unless you go to SOR, at $500 a set). But, if you’re persistent in your internet search, you can order from the UK, and pay the shipping (96 rollers and 56 rollers). You’ll still spend $100…but it ain’t $500 (LOL). Below picture shows the gear train assembled.
Part 4: this last weekend, we got the rig up on the lift and pulled the old and installed the new. Still got quite a few hours of fab time plus powder coating modified skid plates, brackets and linkage bits, buts she’s installed…we can see the light at the end of the tunnel. One of the items a sorta’ kinda’ worried about was reusing my other unobtainable part, the Man-A-Free disk parking brake. We ended up ‘re-indexing’ the caliper plate so the little Airheart brake clears the cross member and allowed clearance for the speedo drive. Anyway, as the photos show, it all fits.
So when I finish this project up, I’ll finish up this entry.
Bee good, and keep the shinny side up…my FJ40 friends.
MMJennings
MMJennings
