so, i have a '94, it has a Viscous Coupler, which i haven't removed - yet my research says i want it gone;
i just bought five 1/2 used BFG KO MT tires; at 1/5th the cost over new, jumped on it, didn't think..
catch: 3 are worn with 8mm tread left. 2 are worn with 6mm tread left.
i thought i'd try some math, but i'm hoping for more of a 80 series mechanical functioning discussion/ info/thx/please
it's maybe a 1/4 inch difference in rolling distance (circumference) on a 255/85/16 (assuming full 33 in diameter - minus wear*pi= 102.63 vs 102.88 inches [.25" difference]; 623 rev per mile.
so that's 155 inches difference in travel/ mile, or .246% different roll/mile
- is math even needed..?
is there anyone with real experience or knowledge who'd avoid this dilemma here?
or should i take them to be mounted without worry, all good. - planning to balance with CounterAct. (made in Canada)
who could comment on the 80 series' All-Time 4WD drive train, VC and the center diff and the front diff and rear diff and what happens with slightly differently worn tires at each axle?
- my research tells me, if i remove the VC and drive unlocked on paved roads, i'm fine.
but still, so many questions and IDK.
which axle should get the larger diameter, or better, MT tires?
now, what if my diff lock button gets activated, or the VC is seized?
or, what if i need to use the 8mm tread spare on the same axle as the 6mm tread tire, would that ruin my respective diff?
too many questions to list, i suppose i'm nervous, much obliged.
to 80 series tech.
