I have a OME 3 inch lift on my '97 FZJ80 and am currently using an adjustable rear panhard rod. I am going to install a Delta VS panhard lift soon but wanted to know if I needed to acquire an OEM Panhard rod or if I could adjust/shorten the current rod to fit to the new lift bracket. If I am able to use the adjustable panhard, how long is the OEM panhard rod? Is that even how long it should be Or is there a good reference someone cam point me to on how to properly adjust the length of the panhard once it is installed with the lift bracket so that it is the proper length?
After some searching did find some information on the lift bracket but no dimensions or recommendations on using OEM vs Adjustable rods.
Thanks
Scott
Thanks
Scott
