More electrical questions (Voltage this time)
Los Angeles, CA
So I just rewired all the melted stuff in my dash after finding what I seem to think is the issue. Everything’s all back together but I have a voltage question. It looks like my meter on the gushes is reading that I’m at or close to 28~ volts at a cold start and fluctuates a volt or 2 occasionally. Is this normal or something that needs to be addressed. It’s a 24v system
Thanks!
Ethan
1986 HJ60
First of all those dash gages are notoriously innacurate. Before I got too worried about that voltage I would be measuring the voltage at your battery. In a 12v system the normal battery resting voltage is 12.6V.....running volage is 13-14.4 volts. I imaging then in a 24v system the normal running voltage is 26 to 28.8V?
That looks normal.
Measure at the battery posts with a hand held volt meter to see what’s really going on. 28.6V is fine (and normal) for a 24V system that’s charging.
I checked both of the batteries and looks like I’m getting 13.6-14.6 on one and 14-15 on the other. This in the okay zone?
15 sounds a little high but both sound like they are about where they should be.
Looks like I actually might be needing a new alternator. The battery and filter light flash together occasionally.
Anyone know someone in LA area that rebuilds 24volt alternators or could source one?
I bet these guys can do it.
They do everything alternator.
I got my rebuilt from them (12 V) and it worked better than any alternator I got in the past.
Ooooo thank you! I’ll have to give them a call
Maybe remove the brown "ring" and have 3 mm extra for the brushes:
New brushes: 2 euro
These outlast the dynamo said the enigeer, very hard brushes.
hardly ever replaces tem.
27371-56070
denso, jndx32
cnd-ft313
5 x 8x28mm
624.2551.90
Replaces
Isuzu 5-81215-018-0
28.0 X 8.0 X 5.0
2 per set
JNDX 32 = FT 313
many pictures of replacing brushes and 24v from fsm: hj60-24V glow,alternator,dome,buzzer,battery, electrics - https://www.tapatalk.com/groups/hj60/viewtopic.php?p=326#p326
easy to charge a bit more, new modern batteries can handle 14.8 v >15
