- Location
- United States
Just moved back to the mainland, selling off my parts accumulation to continue my FJ40 Build. Various parts from two different rigs, a 1984 FJ60, and a 1971 FJ40.
EGR Cooler
| 047-04C-U |
FJ40, FJ45, FJ55, FJ60/62, FJ80 and FZJ80 Land Cruiser EGR Components - Specter Off-RoadToyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...
| $220 | |
EGR Pipe (Flex)
| 047-06D-U |
| 80 | |
EGR Pipe Ball Sleeve
| 047-26A-U |
| 10 | |
EGR Pipe Nut (Fitting)
| 047-27C-U |
| 25 | |
EGR Pipe
| 047-02K-U |
| 100 | |
EGR Bracket Stay
| 047-18D |
| 80 | |
Intake/Exhaust Manifold
| 044-20C-U |
FJ40, FJ55 and FJ60 Land Cruiser Intake and Exhaust Manifold Gaskets, Heat Riser Gaskets and Hardware - Specter Off-RoadToyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...
| $ 800.00 | |
1971 3spd Rear DS
| $ 200.00 | |||
Air Manifold
| 048-20E-U |
FJ40, FJ45, FJ55, FJ60, FJ80 and FZJ80 Emissions Air/Smog Pump System - Specter Off-RoadToyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...
| $ 250.00 | |
Air Bypass Valve
| 048-05G-U | FJ40, FJ45, FJ55, FJ60, FJ80 and FZJ80 Land Cruiser Emissions Air Pump System - https://www.sor.com/cat048.sor#A048D | $ 325.00 | |
Valve Outer Vent Control
| 048-31A-U |
| $ 50 | |
Charcoal Canister
| 048-30G-U |
| 150 | |
2F Carburetor
| 042-01M-R |
Search by Part Number 042-01M | $ 1,000.00 | |
F Carb Insulator FJ40 | 042-02D-U |
FJ40, FJ45, FJ55 and FJ60 Land Cruiser Carburetors, Parts, Kits & Gaskets9/69-7/87 Land Cruiser Carburetors, carburetor rebuild kits, rebuilt land cruiser carburetors, jets, gaskets, non USA carburetors
| $ 80.00 | |
2f Carb Insulator
| 042-02H |
| $ 80.00 | |
F Carburetor | 042-01D-R |
| $ 850.00 | |
Air Cleaner Assembly
| 012-20L-U |
FJ40, FJ45, FJ55, FJ60, 62, FJ80, FZJ80, and UZH100 Land Cruiser Air Cleaner and Filter Assembly - Specter Off-RoadToyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...
| $ 475.00 | |
4/ 5 Speed Trans Boot FJ60 | 116-02L |
Transmission/Transfercase Shift Boots & Knobs - Specter Off-RoadToyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...
| $15 | |
Trans Case Boot
| 116-06L-U |
| $50 | |
Transmission Cover
| 116-11L-U |
Transmission Hump - Running Board & Tool Box - Specter Off-RoadToyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...
| $150 | |
Battery Support Tray
| 019-30A-U |
FJ40 Battery Tray Components - Specter Off-RoadToyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...
| $ 120.00 | |
Right Front Motor mount Bracket
| 040-01A-U |
F, 2F, 3F 1FZ and 2UZ-FE FJ40, FJ45, FJ55, FJ60, FJ62, FJ80, FZJ80, UZJ100 Land Cruiser Motor Mounts - Specter Off-RoadToyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...
| $ 120.00 | |
Vacuum Shift Lever
| Various |
| $ 130.00 | |
Vacuum Switch Assembly
| Various |
FJ40, FJ45 and FJ55 Vacuum Transfer Shift Assembly, 1958-9/71 Land Cruiser - Specter Off-RoadToyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...
| $ 300.00 | |
Vacuum Piping
| $ 200.00 | |||
FJ40LV Evaporative Emission Control Device
| UNK | $ 30.00 | ||
Horn
| 190-51B-D-U |
FJ40, FJ45, FJ55, FJ60, FJ62, FJ80, FZJ80 Horn, horn relay, horn button, steering wheel pad - 1958-1/98 Land Cruiser - Specter Off-RoadToyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...
| $ 100.00 | |
High Alt Control (HAC) Valve
| 048-48B-U |
FJ40, FJ60, FJ80, FZJ80 and UZJ100 Emission Vacuum Pipe and Tube 1/79-2006 - Specter Off-RoadToyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...
| $ 80.00 | |
EGR Modulator
| 047-65C-U | 80 | ||
VCV Valve
| 048-50K-U |
| $ 80.00 | |
EGR Sensor
| 047-75C |
| $175 | |
EGR Valve
| 047-07W-U |
| $ 325 | |
EGR Inlet
| 047-46B-U |
| $ 70 |
