SOLD Monterey, CA - Various FJ40/FJ60 Parts
Status
Not open for further replies.
@Milkshake Do you have an air cleaner assembly for a 1979 2F FJ40?
thanks
hi, is that VCV part California approved? and do you have any info showing how it is installed? thanks
I don't know if it is California approved. The Fj60 came from Colorado. It is currently sitting in a box in my garage, as all of the parts were taken off the motor while I was swapping it into my 40.
FJ60 EGR Cooler $200
FJ60 EGR Pipe (Flex) $80
FJ60 EGR Pipe $80
FJ60 EGR Bracket Stay $50
1971 FJ40 Intake/Exhaust Manifold $600
1971 3spd Rear DS $200
FJ60 Air Manifold $225
FJ60 Air Bypass Valve $325
FJ60 Charcoal Canister $200
FJ60 2F Carburetor $250
F Carb Insulator $50
FJ60 2f Carb Insulator $50
F Carburetor $100
FJ60 Air Cleaner Assembly $450
FJ60 4/ 5 Speed Trans Boot $15
FJ60 Trans Case Boot $30
FJ60 Transmission Cover $100
Fj40 Battery Support Tray $120
FJ40 Right Front Motor mount Bracket $75
Fj40 Vacuum Shift Lever $100
Fj40 Vacuum Switch Assembly $200
FJ60 Vacuum Piping $30
FJ40LV Evaporative Emission Control Device $30
Fj40 Horn $50
FJ60 High Alt Control (HAC) Valve $75
FJ60 EGR Modulator $75
FJ60 VCV Valve $75
FJ60 EGR Sensor $150
FJ60 EGR Valve $150
FJ60 EGR Inlet $50
Everything is OBO. I don't have a huge amount of experience with parts prices, just trying to discount 20-30% off what I see used parts online from distributors. Make me an offer, if it's reasonable I'll probably accept so I can chip away at my shopping list for my build.
Do you still have the F carburetor
Still have the following parts, plus a few new additions:
1984 FJ60 Parts
Emissions Vacuum Piping
VCV Valve
EGR Assembly (Valve, Sensor, Inlet)
EGR Modulator Charcoal Canister/Outer Vent Control Valve
Air Manifold (Smog/emissions)
Air Bypass Valve
EGR Cooler
Front and Rear Leaf Springs
Chrome Wheels
9.5 in Ring and Pinion (3.70 ratio)
1971 FJ40 Parts
FJ40 Motor Mount Bracket
Rear Driveshaft
Again, all OBO, Willing to ship. I can send additional photos of the items you're interested in.
Hey sir! I’m in need of the bracket that sits on the driver fender that holds the EGR and other smog paraphernalia. I need the various brackets attached to this larger bracket as well. Do you have this?
Thanks!
Thanks!
I will look through my parts bin and let you know.
I don't know exactly which bracket you're looking for, but various parts have brackets on them. For example, here is another angle of the Air Bypass Valve.
Do you have a picture/part number of the bracket you're talking about?
Hey! Thanks for the reply. It looks like it’s all attached to everything going on there. I started looking at fabbing something. I’m desmog fed so I just need to mount a couple items.
Thanks again for your time!!
Status
