If it's been 10 years, I'd recommend going for at least the end of axle repack if not a full front axle service.
If the addition of moly leads to the ball getting an even coasting of grease on the ball, then not so urgent. You should be able to take out the square fill plug and shine a light in to see that the moly grease at least partially covers the birf inside. Another thing is to ensure the seal between the moly in the trunnion box and the gear oil in the inner axle hasn't failed. If you haven't looked underneath in 10 yars, it's possible that the inner axle seal failed it flung much of the gear oil. Which would have flung gear oil all over the inside sidewall of the front tire. It could've done that and then had it washyed off in th coiurse of 10 years of driving.
Pull the fill plug on the front diff. Check the level of the gear oil, which should be full up to where it comes up to just where it starts to dripout with the plug removed. If it's still full up, you're probably OK. If low, then you should consider the full axle service.
