Moab trip report, perspective & retrospective (1 Viewer)
tbisaacs
It's basically a Land Cruiser
Renton, WA
Website
instagram.com
I rolled in like a dusty cowboy last night after blasting 17 hours straight back to the Seattle area from an amazing long weekend in Moab. This is my third trip there, first time with other drivers (and most importantly, spotters!) and boy was it a blast. Most importantly, after Moab, big trips like Sedona, and multiple LCDCs, I'm ready to certify this rig as..proven. It was an amazing experience—everyone should go at least once.
Planning
I wish I was the kind of person who could just hop in the car, meander and just point and shoot to whatever trail feels right, but I ain't him. I was also bringing two first-timers and wanted to make sure they had a great time as well so I spent a lot of time researching, searching YouTube, and flipping through the FunTreks book. I also created some specific criteria for the week:
  • Maximize fun while minimizing mechanical risk
  • Avoid risky off-camber slick rock
  • Focus on only in Moab scenery: dunes, slickrock, canyons, caves, buttes
  • Provide several duration options so we can mix and match depending on how we’re feeling
  • Focus on trails that I’ve seen Land Cruiser sized / IFS vehicles successfully complete
Funny enough, deep in the archives of YouTube I came across a lot of rigs and faces that I recognize from what I assume was past cruise Moab events— @mcgaskins, @Romer , @TheGrrrrr , @Markuson to name a few. The original plan was 4 days of wheeling, gradually increasing in difficulty and finishing the week with Poison Spider or Top of the World. We ended up calling it short of that, but more on that later. We finished the week running Hurrah pass, Chicken Corners, 7 mile rim (twice-ish), and Fins-and-things.
In terms of making sure my rig came home, I packed the following:
  • ARB Jack
  • ARB tire puncture kit
  • Glue Tread
  • Spare axle, output seal and hub socket
  • Spare fluids (no more AHC fluid and syringe this year!)
  • Spare headlight bulb
  • Spare u-joint
  • Spare fuses/breakers
  • Compact impact and sockets, breaker bar, big hammer and cheater pipe
Thankfully, there were no break glass in case of emergency moments.
Rig Postmortem
My rig did amazing and came home whole, only with a few new "from Moab, with love" scratches mainly on the corners, the armor, and a few new marks on the skid plates.
  • I discovered that my EE Offroad skids were missing 5-6 bolts from the skins due to neglect on my part—I never checked them after installation. Thankfully I found some replacements at the local Moab ACE hardware. My cat guards are also very loose.
  • There is a piece of AHC line flopping around on a cross member that occasionally would knock after a big whoop and it freaked me out first couple of times
  • The ride was pretty miserable at first, dampening was great but truck was so busy and rocking side by side. I increased the rebound on my dobinsons +2 and holy crap, different truck. It felt composed and athletic even at moderate speeds. I still wouldn't jump it though :)
  • I am missing a bunch of driver side fender liner due to aggressive rubbing. When I had my SPC UCAs installed, I didn't know what I didn't know and they are set up for maximum caster and the wheel is just getting too close to the rear of the wheel at full stuff—which it does freely with the skinny AHC sway bar.
My buddy Adam brought a mostly stock triple-locked 80 series and it did amazing all week with exception of needing to baby sit a leaking berf
My other friend brought an 80 that he just picked up that's a monster—LT1 V8, triple locked, transfer case reduction, 37x13.50 and the biggest rear links I've ever seen. Unfortunately he blew a power steering line between the pump and brake booster and we had to quickly limp him off the trail before he lost the pump and belt.
There is a story here: I pulled up too far letting some rowdy SxS traffic by and got stuck in the berm, off camber and the rear got light. Ended up being a quick winch pull off my buddy as an anchor:
Capability and performance
At this point, my only limitation is my confidence. This rig performs beautifully. In fact I did 90% of the weekend with my center diff unlocked. Big traction, flex, big tires, and big clearance are the great equalizer. I was also worried about holding back my friends in their triple-locked 80s, but not the case. The 200 doesn't give anything up.
One thing I noticed immediately is that my real travel has increased noticeably between the slightly longer rear shocks and 50mm sway bar drop brackets from Superior. I felt it, but saw it too—here's a screen capture from a video:
This made crawling up BIG ledges super easy. Everything I thought I would high center on, I just stepped up and climbed. As long as my bull bar would clear it, it was point and shoot.
The Dobinsons + PerryParts bumpstops made this trip so enjoyable as compared to my AHC experience in past trips like LCDC. Once the I dialed in rebound, my truck was poised and confident and comfortable.
Lastly. I got my Level 2, certified junior rock crawler badge. I took as many hardlines as possible, only opting out of the big double step wall, and wipeout hill on 7 mile rim—but truthfully it was because I was scared, not because I didn't have enough rig. Here's a quick edit of clips my friend's recorded:
Beautiful photos, as always, and love the write up!
Great photos and info. I plan on going in October. Hoping to get on a few trails at least.
However I’ll be with a mostly stock f-150 unless I can talk my significant other into taking the 40 🤣🤣
Souvenirs from the ledges:
A little gift from toaster rock
Fender liner is begging for mercy:
I dont remember hitting the belly but I guess I did
How much of this could have been done with a “stock” f-150 on good 33s and rear locker?
Also a driver with zero experience
Oh way more scratches, scraps, and dents could have been achieved in a stock F150.
There are lots of options in Moab where you’d be fine. I would not recommend any of the hard trails unless you have an experienced spotter and are okay with dragging bumpers and steps and frame slides in the F-150
I would love to run some of the harder trails in my 200 while we are there. But the couple we are going with are in a stock f150 so we will probably stick to basically dirt roads.
Highly recommend getting the FunTreks book. There are so many scenic options that won’t stress out your friends
There is a back way into Arches National Park that I highly recommend that a stock 150 could do. We did it solo in my 200 and saw several stock pickups and SUVs. Nothing crazy or hard but not just a dirt road either. Several options on the route that connect to the paved road in the park. You exit through the main entrance. It was nice and relaxing and allowed us to get to some arches and hike a short way into them that you could not get to from the paved road. DM me and I can send you details.
