- Year
- 1992
- Vehicle Model
- 80 Series
- Mileage
- 214000
It pains me to sell the cruiser but it is time to move on. I have no time to dedicate to it, plus I am in the middle of a move where I downsized from 3000 sq ft combined of garage and shop space to just under 400 sq ft.
I purchased this cruiser in May of 2019 and drove it that summer and fall. Feb of 2020, it started to get warm on the way home from an overland trip. Coolant spewed out of the reservoir. After refilling the radiator 2 times in 30 minutes I ended up towing it home. Long story short - the block was cracked in cylinder 6. It took me a while to get it all figured out and accumulate parts but finally got it back on the road a May 2021.
The block had liners installed in all 6 holes, honed for STD pistons. OEM pistons installed. The head was re-conditioned. Head and block was surfaced, New Taiho BEB's, crank bearings, OEM trust bearings, OEM cam bearings. Toyota gaskets and seals.
Less than 500 miles after the rebuild, my cooling system started pressurizing again but not to the same extent before the rebuild.
The cruiser does have a GTurbo BadBoy (red wheel) set at 22-25lbs. The only thing I can think of is maybe the head gasket did not seat adequately (I re-used the head bolts) and maybe I pushed boost a little too hard before fulling breaking it in? I don't have time to dig in on this anymore and need to pass it on.
Things it needs, and other concerns (other than the engine)
- Front knuckle service
- rear diff pinion seal
- brakes are a little weak
- rusty left side rocker panel
- rust in right front wheel well under the battery
- rear window wiper does not work
- front bumper bruised
- rear locker engages but light flashes on dash
- A/c works but is not very cold
- exhaust flex joint at turbo downpipe leaks
- Intercooler water pump works, but should be upgraded
New parts & improvements (other than engine)
- GTurbo Badboy
- Air to water intercooler
- ISSPRO EGT/Boost gauge with Aircraft spruce micro1000 probe pre-turbo
- Newer A/c compressor, dryer, accumulator
- bluetooth head unit
Not included
- Roof rack
- SCS F5's (other wheels with 305’s M/T's included)
Other details
- 345,000 Km's
- lifted 2" to 3" ?? unknown brand springs/shocks
- OME steering stabilizer
- stainless 2.5" turbo back exhaust
- front, rear, and center lockers
Engine details
- Block cleaned inspected, bored out for liners in all 6 cylinders
- Liners bored to STD spec
- New OEM '92 and later pistons
- pistons, pins, and rods weight matched
- New TAIHO BEB's
- New TAIHO crank bearings
- New OEM cam bearings
- New OEM cam and crank thrust bearings
- New Toyota gaskets and seals
- head reconditioned and surfaced
- IP timing set to 1.35mm
- while in my possession, only used OEM filters
The cruiser starts up on first crank. It's driveable. You can drive it continuous on the road or highway for about 60 miles before needing to top off the coolant or parking it for a while. I have been driving it around town running errands. The expansion tank will fill up a little and then when turned off and set to cool, coolant will eventually get sucked back into the radiator. I put a pressure gauge on the cooling system on a cold start and within a minute, pressure is built up to near 15 psi with cold coolant. I haven't performed it's first oil change after rebuild - it is due (about 500 miles since rebuild)
Located in Branson, MO
I'm asking $15,000 but am open to serious offers and trades.
Clean Missouri title
- GTurbo Badboy
Not included
- Roof rack
Other details
- 345,000 Km's
Engine details
- New TAIHO BEB's
