Everyone is entitled to their opinion, but for anyone reading this thread, please don't immediately take the post I quoted as fact. The Simply Speaker replacement surrounds are NOT foam, and will last a very long time.
To an earlier poster re/ disintegrating foam being a cause of poor sound.. The foam surround's two main purposes are to keep the voice coil centered so that it moves freely around the speaker magnet, which in turn moves the cone, which is what moves the air and creates sound. The foam also acts like a damping mechanism, similar to a shock absorber. It doesn't have anything directly to do w/ sound quality, but when it disintegrates the voice coil rubs against the magnet impeding motion, and the speaker also goes past it's design excursion parameters... like bottoming out when your shocks completely give up the ghost. Both of these things cause the buzzing and distortion you're hearing. Replacing that surround foam is a simple, easy process and will return your speakers to as-new performance, provided the voice coils aren't burnt out (and they probably are NOT... they're most likely fine).
Now, regarding the opinion stated above about the "garbage" status of the ML system. I could not disagree more strongly. If you're looking for body-shaking, mind-numbing bass that'll shake the other cars off the road, or ear-bleed-inducing screechy treble like most of the car audio systems I've heard, then yes, you may not like the ML system. However, if you listen to acoustic music, or any type of music where fidelity to the source is important to you, then the ML system is one of the best out there. My wife and I are both professional musicians, and her ONLY criteria for her next car is that it, too, has the ML system in it.
Sooo... like I said, everyone has opinions, and are definitely entitled to them. Form your own... fix your ML system and decide for yourself. I doubt VERY much that you'll consider it garbage, and I'm fairly sure you will appreciate it a great deal... and increasingly the more you listen.
If you actually care about fidelity and consider yourself an audiophile as I do the ML system is not up to par. The Nakamichi system in the last generation LS400 absolutely destroys it. Has nothing to do with wanting ghetto blaster levels of bass, but a properly sourced and installed aftermarket set of components even with the stock head unit and maybe the stock amplifiers can go a *long* way toward improving what's there . FWIW, this is coming from someone who owns or has owned Bowers and Wilkins Diamond 802, 803 and 804 speakers connected to McIntosh MC601 dual mono amplifiers, among dozens of other both inexpensive and upper end audio system components. (As a side note, the best factory system you can buy at any price right now is the B&W Diamond system in the current 7 Series and *only* that car unfortunately if you want the lauded Diamond tweeters. It's a 3300.00 option and worth every penny as it is absolutely sublime). However what is correct here is that everyone has different levels of quality they're willing to accept and be satisfied. That is different for every person.
As for the point about the material that is used in the refoam process, if you noticed I actually said that if it is foam the problem would re-occur within a matter of time. Not necessarily that is just foam. And if not, that's great.
