I'm still pretty sold on the MM 211, but I found a slightly older MM 210 for sale locally. Wondering if I should consider it instead.
Thanks, I was hoping you'd reply.
I have no need for it to be portable. I don't think it's "old" but the MM 210 came out in 2005, its been replaced in their product line with the 212/AS, which is a lot more money that I can spend to buy new. This used one is only $900, no bottle though. I believe it's a tapped model, only has 7 voltage settings, not infinite settings like the newer 211 has. Not sure how big of a deal that is. One thing that concerns me is the spec sheet from Miller says the included M-25 gun is suitable for 0.030/0.035 wire. What if I wanna go smaller on the wire, say down to 0.024 for doing sheetmetal work? Do I have to get a different gun?
I'm seeing 211/AS kits on eBay for ~$1,250 delivered, with a cart and spoolgun. The MVP feature is kinda cool, although I'm more interested in the Autoset.
Autoset feature doesn't do anything for me. If you spend some time with it, you'll quickly "learn" what setting you need to use. I always practice on metal of the same thickness first to dial in the setting I want to use. Good chance the input power (from receptacle) will vary a few volts depending on when you use it.
You can install a .023 liner in the M25 mig gun. Another option would be to buy a smaller mig gun for sheet metal work. I just use my little 110v Millermatic 130 for sheet metal work.
You might want to read up on Hobart Ironman 230 that should be available soon. It will do 250 amps and has a bunch of voltage taps. It has gotten great reviews from a tester.
Hobart Welders - Products - Wire Feed Welders - IronMan 230
Understood on the Autoset. I won't be using this daily, so I need to be able to pick up the gun and go, without re-learning the optimal settings.
oofff... sounds like a pita, and having a second box seems silly.
I'm sure it's a nice unit, but $1500 is way over my budget, and there's still no spoolgun included.
Thanks for the info, very helpful.
